Document Server version:9.0
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS:
Browser version:
Additional information:
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
您好 @kisswhy!
感谢您的跟进!关于您提到的部分限制编辑功能(类似于 MS Word 的“允许对受保护的 Word 文档的某些部分进行更改”),请问您是否指的就是这个需求?详情见:Could you support the model of restricted editing ? - #7 by softboy99
为了更好地理解您的场景,能否请您更详细地描述一下?例如,您希望在哪些具体部分允许编辑(文本、表格、图像等),以及您的使用环境(离线/在线版本)?
我很乐意尽力帮您!期待您的回复。
