For feature suggestions, describe the result you would like to achieve in detail:
I would like Onlyoffice to convert files correctly and open them in NextCloud. Unfortunately, now when Onlyoffice is enabled, NextCloud freezes and does not respond after adding new files.
When I start OpenOffice, I get the following message:
[2025-09-04T06:41:49.195] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 20; availableParallelism: 20
[2025-09-04T06:41:49.196] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
[2025-09-04T06:41:49.200] [WARN] [localhost] [docId] [userId] nodeJS - worker 879 started.
[2025-09-04T06:41:49.200] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 20; availableParallelism: 20
[2025-09-04T06:41:49.201] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
[2025-09-04T06:42:04.350] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 20; availableParallelism: 20
[2025-09-04T06:42:04.351] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
[2025-09-04T06:42:04.354] [WARN] [localhost] [docId] [userId] nodeJS - worker 1209 started.
[2025-09-04T06:42:04.355] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 20; availableParallelism: 20
[2025-09-04T06:42:04.355] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
Log File:
[1]+ Stopped docker stats OnlyOfficeDocumentServer
root@KulisUnRaid:~# docker exec -it OnlyOfficeDocumentServer tail -n 100 /var/log/onlyoffice/documentserver/docservice/out.log
[2025-09-03T21:08:24.829] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2025-09-03T21:08:24.834] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
[2025-09-03T21:08:24.991] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 9.0.4. Build: 50
[2025-09-03T21:08:39.391] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2025-09-03T21:08:39.396] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
[2025-09-03T21:08:39.497] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 9.0.4. Build: 50
[2025-09-04T06:39:16.264] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2025-09-04T06:39:16.269] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
[2025-09-04T06:39:16.394] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 9.0.4. Build: 50
[2025-09-04T06:39:30.361] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2025-09-04T06:39:30.366] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
[2025-09-04T06:39:30.466] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 9.0.4. Build: 50
[2025-09-04T06:41:49.353] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2025-09-04T06:41:49.358] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
[2025-09-04T06:41:49.462] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 9.0.4. Build: 50
[2025-09-04T06:42:02.984] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2025-09-04T06:42:02.989] [WARN] [localhost] [docId] [userId] nodeJS - notifyLicenseExpiration(): expiration date is not defined
[2025-09-04T06:42:03.094] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 9.0.4. Build: 50
When I added files to NextCloud:
==> /var/log/onlyoffice/documentserver/converter/out.log <==
[2025-09-04T06:52:19.455] [ERROR] [localhost] [2543239713] [userId] nodeJS - error downloadFile:url=https://nextcloud.webbpages.com/apps/onlyoffice/download?doc=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY3Rpb24iOiJkb3dubG9hZCIsImZpbGVJZCI6ODMwLCJ1c2VySWQiOiJLdWxpcyJ9.GhJy9rVgNMNhaMgm2qW1FJrFqKNN8DM7WRRE1ueQICg;attempt=1;code:ERR_BAD_RESPONSE;connect:undefined AxiosError: Request failed with status code 504
at settle (/snapshot/server/Common/node_modules/axios/dist/node/axios.cjs)
at RedirectableRequest.handleResponse (/snapshot/server/Common/node_modules/axios/dist/node/axios.cjs)
at RedirectableRequest.emit (node:events:536:35)
at RedirectableRequest._processResponse (/snapshot/server/Common/node_modules/follow-redirects/index.js:409:10)
at ClientRequest.<anonymous> (/snapshot/server/Common/node_modules/follow-redirects/index.js:102:12)
at Object.onceWrapper (node:events:639:26)
at ClientRequest.emit (node:events:524:28)
at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
at TLSSocket.socketOnData (node:_http_client:544:22)
at Axios.request (/snapshot/server/Common/node_modules/axios/dist/node/axios.cjs)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async Object.downloadUrlPromise (/snapshot/server/Common/sources/utils.js)
==> /var/log/onlyoffice/documentserver/nginx.error.log <==
2025/09/04 06:52:19 [error] 9475#9475: *130 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=2543239713 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=2543239713", host: "onlyoffice.webbpages.com"
2025/09/04 06:52:19 [error] 9475#9475: *132 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=1316968210 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=1316968210", host: "onlyoffice.webbpages.com"
2025/09/04 06:52:19 [error] 9475#9475: *134 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=3117703769 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=3117703769", host: "onlyoffice.webbpages.com"
2025/09/04 06:52:19 [error] 9475#9475: *136 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=858906425 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=858906425", host: "onlyoffice.webbpages.com"
2025/09/04 06:52:20 [error] 9475#9475: *138 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=217924490 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=217924490", host: "onlyoffice.webbpages.com"
[2025-09-04T06:53:20.506] [ERROR] [localhost] [2543239713] [userId] nodeJS - error downloadFile:url=https://nextcloud.webbpages.com/apps/onlyoffice/download?doc=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY3Rpb24iOiJkb3dubG9hZCIsImZpbGVJZCI6ODMwLCJ1c2VySWQiOiJLdWxpcyJ9.GhJy9rVgNMNhaMgm2qW1FJrFqKNN8DM7WRRE1ueQICg;attempt=2;code:ERR_BAD_RESPONSE;connect:undefined AxiosError: Request failed with status code 504
2025/09/04 06:53:19 [error] 9475#9475: *140 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=3744946139 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=3744946139", host: "onlyoffice.webbpages.com"
2025/09/04 06:53:19 [error] 9475#9475: *142 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=2826449327 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=2826449327", host: "onlyoffice.webbpages.com"
2025/09/04 06:53:19 [error] 9475#9475: *144 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=3789763150 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=3789763150", host: "onlyoffice.webbpages.com"
2025/09/04 06:53:19 [error] 9475#9475: *146 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=3440907233 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=3440907233", host: "onlyoffice.webbpages.com"
2025/09/04 06:53:20 [error] 9475#9475: *148 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.18.0.1, server: , request: "POST /converter?shardKey=410152126 HTTP/1.1", upstream: "http://127.0.0.1:8000/converter?shardKey=410152126", host: "onlyoffice.webbpages.com"
Document Server version:
9.0.4
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
Docker
Connector version:
9.0.4.50
DMS (platform) version:
Linux from LinuxServers Docker.
OS:
Unraid
Browser version:
OperaGX 121.0.5600.47/Safari
Additional information:
It seems to me that most of the time everything worked fine when I added individual files. OpenOffice is on DNS via Cloudflare.
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage).
I use CloudFlare and Nginx.
