OnlyOffice conversion error (-83) when processing large XLS files
Dear all,
I am using OnlyOffice Document Server v9.3.1 on a Red Hat Enterprise Linux 9 environment with 16GB RAM.
I am using the conversion API to convert XLS files to XLSX format.
For small files, the conversion works without any issues.
However, when converting a large file (~1GB), the process sometimes succeeds, but occasionally fails with the following error in the docservice log:
/var/log/onlyoffice/documentserver/docservice/out.log
[2026-03-26T13:40:26.801] [ERROR] [localhost] [conv_71dc35dc2b984a53] [userId] nodeJS - convert-to error status:{"err":-83,"end":false}
Could you please advise on the possible cause of this issue and how to resolve it?
Best regards,
Hi @anhtt,
To fix this, try to increase a few limits:
  1. In /etc/onlyoffice/documentserver/local.json, raise FileConverter.converter.timeout (default is 120000 ms — try 600000) and FileConverter.converter.maxDownloadBytes to at least 2GB.
  2. In your nginx config, raise proxy_read_timeout (e.g. 600) and client_max_body_size (e.g. 2g).
  3. Restart services: systemctl restart ds-* && nginx -s reload
If the issue persists, could you share the logs from /var/log/onlyoffice/documentserver/ captured during a failed conversion?
