NodeJS fail / UNABLE_TO_GET_ISSUER_CERT_LOCALLY
Do you want to: NodeJS fail / UNABLE_TO_GET_ISSUER_CERT_LOCALLY;connect:undefined Error: unable to get local issuer certificate
Document Server version: 9.0.3 (NodeJS 6.13)
Type of installation of the Document Server: deb/rpm
OS: Ubuntu 22.02
Browser version: FF/Chrome
Additional information:
Good morning,
I have the problem with the certificate verification by Node.js since the change from OnlyOffice 8.3 to 9.0.3.
Currently the verification in the default.json has been deactivated:
rejectUnauthorized": false
However, this should not be a permanent state, but should be reactivated. The root and the server certificate are located under /etc/ssl/cert and were also verified using openssl -verify.
There is an option to change or add Node.js to openssl in the systemd services:
sudo nano /lib/systemd/system/ds-docservice.service
sudo nano /lib/systemd/system/ds-converter.service
environment=NODE_ENV=production-linux NODE_OPTIONS=–use-openssl-ca …
Unfortunately this does not bring any improvement, the error message still appears.
Error message:
[ERROR] [localhost] [3980854427] [ocw5d89cjctv_USER] nodeJS - error downloadFile:url=https://URL
Would you have any tips on where I could start here with OnlyOffice or Node.js so that the verification works again?
Thank you very much
Hey @dropmen :wave:
Thanks for the details!
This issue is likely due to Node.js not recognizing your certificate chain. Here’s what you can try:
1. Create a custom CA bundle
Join your root and intermediate certs into one file.
2. Edit systemd service files
Open these files:
Add this line under [Service] (use your actual path):
Environment="NODE_EXTRA_CA_CERTS=/etc/ssl/certs/custom-ca-bundle.crt"
3. Restart services
sudo systemctl restart ds-docservice ds-converter
Let us know how it goes!
Perfect, that’s exactly what it was! Many thanks for the help! :partying_face: :partying_face:
