I am running into a persistent JWT issue between Nextcloud 32.0.5
and OnlyOffice Document Server (Docker) and would appreciate
guidance from someone familiar with the internal JWT validation logic.
Environment
Nextcloud
- Version: 32.0.5
- OS: Debian (DietPi on Odroid HC4)
- Webserver: NGINX
- PHP: 8.4 (php8.4-fpm)
- OnlyOffice App: 9.12.0
OnlyOffice
- Document Server running in Docker
- Docker IP: 172.17.0.2
- Host public IP: ExternalIP
- OS: Debian 11
Problem
When opening or editing documents, I get the following errors in
Nextcloud:
1) Health check
[onlyoffice] getConvertedUri on check error
2) Callback
[onlyoffice] Track with invalid jwt in body
POST /index.php/apps/onlyoffice/track
3) Download
[onlyoffice] Download with invalid jwt
GET /index.php/apps/onlyoffice/download?doc=...
JWT Configuration
OnlyOffice local.json
"token": {
"enable": {
"request": {
"inbox": true,
"outbox": true
"browser": true
"inbox": {
"header": "Authorization",
"inBody": false
"outbox": {
"inBody": false
The secret is correctly set in local.json and matches the one
configured in Nextcloud.
Nextcloud OCC settings
occ config:app:get onlyoffice jwt_secret
occ config:app:get onlyoffice jwt_header
occ config:app:get onlyoffice jwt_header_key
Result:
- jwt_secret → correct and matches OO
- jwt_header → Authorization
- jwt_header_key → Bearer
NGINX (Nextcloud)
Authorization header is passed to PHP-FPM:
fastcgi_param HTTP_AUTHORIZATION $http_authorization;
Special locations for OnlyOffice endpoints:
location = /index.php/apps/onlyoffice/track {
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root/index.php;
fastcgi_buffering off;
fastcgi_request_buffering off;
fastcgi_pass unix:/run/php/php8.4-fpm.sock;
Body buffering disabled for callback route.
What has been verified
- System time synchronized (CET vs UTC difference understood)
- JWT secret identical on both sides
inBodyset to false on OnlyOffice- Header mode set to Authorization/Bearer
- No reverse proxy between systems
- Direct curl from OO container to NC works (HTTP 200/403 as expected
depending on endpoint)
Example from OO container:
docker exec onlyoffice_server curl -i https://cloud.trialogevent.de/index.php/apps/onlyoffice/empty
Returns 403 (expected without valid token).
Question
At this point, it looks like:
- Either Nextcloud signs JWT differently than OnlyOffice expects
- Or OnlyOffice validates a different payload format than NC 32 sends
- Or something changed in NC32 JWT handling compared to NC30 (which
worked)
Has anyone successfully run Nextcloud 32 + OnlyOffice (latest) with
header-based JWT (Authorization: Bearer) and inBody=false?
Is there any known change in JWT validation logic in recent Document
Server versions?
Any insight into what specifically causes Download with invalid jwt
would be greatly appreciated.
Thank you.
