More Layout Guides
Imported from UserVoice
Author: GwentLarry
I’d like to be able to see guidlines for margins, headers, footers, print areas, etc.
When grabbing any of the named items a guideline appears. Do you suggest adding specific setting or visual markers? If so, please share any references for better understanding of your idea.
Thank you.
Many word processors have the View-Gridlines / Guide so that the document’s margins are indicated with a visible guides on all four sides
Hello @ramdoss
Your example only refers to margins, however, according to original description, the user suggested to show guidelines for headers, footers, print areas and so on, which seems a bit unique, thus I wanted to clarify on that.
If you want to suggest specific guide lines, feel free to create a separate suggestion for review.
