Missing Insert and Delete Row/Column
ONLYOFFICE Mobile: Documents / Projects / Web Editors
Do you want to: Report a bug
Device: Motorola Edge 50 Neo
OS version: Android 16
App version: 9.3.1
Mode: On Device
Additional information:
When I click the row or column header (in any document new or existing) there is no insert/delete row/column options on the popup menu. I cannot see any other way of inserting/deleting rows and columns.
I have tried clicking the three dots on the popup menu but this only shows “Show” and “Add comment”.
same problem on my android samsung tablet , no insert/delete row/column options . sometimes tiring to use all these mess…
Hello
Thank you very much for sharing this with us.
We’re aware of the issue, it has already been fixed. The fix will be included in version 9.4
@here. we have just released new version of Mobile app that brings fix to the issue discussed in this topic. Please update the app and check the situation again.
Awesome work, thanks!
This topic was automatically closed 12 hours after the last reply. New replies are no longer allowed.
