Markdown files being forcibly converted to OOXML
In the community edition of DocSpace (v3.2.1), enabling the markdown plugin (v1.1.0) allows me to create a new markdown file with the built-in editor as expected, but after saving it I can only preview the resulting markdown.
Clicking on the .md file or trying to edit it results in DocSpace telling me that it will convert the document to Office Open XML format and I only have the option to continue or close (cancel).
Similarly, uploading any markdown files results in similar behaviour; I’m forced to convert to OOXML. In this case, though I can save a copy in the original formal, I can’t open or edit the original markdown file in DocSpace without being forced to convert to OOXML first. I can only view it by right-clicking and selecting “Preview markdown”.
I’ve looked around in the admin settings and personalisation options, but haven’t found any way to turn off this behavior for .md files.
Hello @bennyb0i
We are aware of this issue. It will be fixed in upcoming release of Markdown plugin (1.2.0) and DocSpace 3.5. Normally, in context menu you should be able to choose Actions > Edit markdown/Preview markdown, but due to a bug, this item in context menu is unavailable.
Sorry for the inconvenience.
Hello again @bennyb0i
Sorry for the delayed response. DocSpace 3.5.0 was released, as well as the plugin. Please update your instance and check the situation with Markdown plugin again.
