Make text field form component background completely transparent
Hi! Even when I set a text field color to be completely white when I open this PDF in Firefox to fill, the field itself is visible (light blue rectangle is shown where the field is located):
This is a problem for me when I want fields to be transparent (with just text being able to be placed inside them) while their background to be any shape. Good example where I need is an English worksheet:
In it I have several rounded rectangles where I would love to insert text fields with text just visible and circles to write just one letter there.
OnlyOffice: Community version 9.1.0.173 (snap)
Firefox: 144.0.2 (64-bit) (snap)
OS: Ubuntu 24.04.3 LTS
Hey @EmilyGraceSeville7cf, :wave:
Thanks for the example! Just to make sure — have you seen this completely transparent form field behaviour working in other editors/viewers (like Adobe Acrobat or Chrome’s PDF viewer)?
From what I know (though I might be wrong), active form fields get that light blue/yellow highlight in pretty much all PDF viewers… it’s like a spec thing to show where you’re typing. But if you’ve got an example where it’s truly invisible, that’d help us understand if it’s possible!
No, I have not yet. :pensive:
