Make it so stationery can be used when writing documents and emails
Imported from UserVoice
Author: Terry Bell
As when using templates, make it possible to use artistic stationery when communicating via email. It would provide a background or border on the screen on which the message is typed. The message field could have a background, and the border could be one or more edges.
Please elaborate on your suggestion. Do you suggest adding an option to set document background as an image? If it is not the case, please provide any additional details.
