Macro help: Insert text run next to each Footnote Reference in body
Hello everyone,
I am trying to create a macro for the Document Editor with a specific goal:
I need to scan the entire document, find every Footnote Reference (the small superscript number in the text), and insert a text Run (like [1], [2], etc.) immediately after it.
Essentially, I want to convert the dynamic footnote reference into a static visual marker in the text, so I can export the content later with these references visible as standard text.
The problem:
I am iterating through all paragraphs and their elements. I am trying to detect the footnote reference using GetClassType() === "footnoteReference", but I am struggling to make it work reliably. The script either doesn’t find the elements, or fails to insert the new Run correctly at the specific index.
Here is the logic I am using. Could someone advise on the correct way to detect a footnoteReference object and insert a text Run immediately after it?
(function () {
    var aParas = oDocument.GetElements(); // (I am using a recursive collector for tables/content, simplified here)
    var noteCounter = 1;
    for (var i = 0; i < aParas.length; i++) {
        var oPara = aParas[i];
        var nElements = oPara.GetElementsCount();
        // Loop through paragraph elements
        for (var j = 0; j < nElements; j++) {
            var el = oPara.GetElement(j);
            // I am trying to detect if 'el' is a footnote reference
            var sType = "";
            try { sType = el.GetClassType(); } catch(e) {}
            if (sType === "footnoteReference") {
                // GOAL: Insert a new Run "[n]" right after this element
                var oRun = Api.CreateRun();
                oRun.AddText("[" + noteCounter + "]");
                // This part fails or doesn't behave as expected:
                // How do I insert oRun at position j+1?
                oPara.AddElement(oRun, j + 1); // This method signature might be wrong
                noteCounter++;
                j++; // Skip the inserted element
                nElements++; // Update count
Does GetClassType() return “footnoteReference” for these objects? Or should I look for a specific property?
Any help or snippet on how to “Inject a Run after a Footnote Reference” would be greatly appreciated.
Thank you!
Hello @Salvodif
Can you share the implementation of your var aParas = oDocument.GetElements() collector? Not every item in the document content would appear as footnoteReference as an element, thus this may be a problem.
Also, just for better overall understanding of the document structure, can you provide a sample document with footnotes as a base for running the macro?
it is a method from Api.GetDocument()
There is no such method as GetElements() in the ApiDocument class. Can you elaborate?
