[ Jitsi plugin ] Failed to start a new conversation without need to run self-hosted instance
Continuing the discussion from Docspace: browser , jitsi:
Hi, I encountered an issue while using Jitsi plugin to start a new conversation.
  1. Without entering the domain field, I only entered a room name in respective field in the plugin and then pressed Start to launch plugin.
  2. Then I pressed Join(In Chinese) to join the meeting.
  3. Then it showed the message, waiting for the moderator, and asked me if I was the moderator, I pressed I am.
  4. Then it turned out to be the start page.
Does the domain name field become necessary? Or did I do something wrong? Looking for the help. Thanks!
Can someone give me advice? THanks a lot!
@ Constantine
Hello, Do you know the reason? I’ll be grateful if you answer me.
Hello @yuting
If you don’t mind I will join this thread.
We’re checking the situation. I will contact you as soon as possible.
Hi, I have created a self-hosted instance for jitsi meet and used a valid domain name. Then we join the meeting successfully. But I met another question about microphone permission in windows11 desktop app.https://community.onlyoffice.com/t/error-obtaining-microphone-permission-when-using-jitsi-plugin-in-windows11-desktop-app/15484 Can you give me some advice? I’ll be grateful for your help.
Hello @yuting
We’ve found a bug on the described scenario in this very thread. We have started working on it.
Thank you for the valuable data!
Great, thanks for handling it! Looking forward to good news.
