Jitsi plugin: default downloading and set the default domain
For feature suggestions, describe the result you would like to achieve in detail:
Document Server version: v.9.0.3
Docspace version: v.3.1.1
Hello! Is there any way to add the Jitsi plugin to the default plugin list so that users do not need to search and download it? And is there any way to set a self-hosted default domain name so that users do not need to edit it every time they join a room? I need some help.
Hello @yuting
Jitsi plugin is not packaged as a default plugin to Desktop Editors. Are you deploying Desktop Editors on several machines?
Do you mean making a specific domain available by default when a user opens Desktop Editors and runs the Jitsi plugin?
