I would like to know if Yandex Docs is still using ONLYOFFICE as their core editor. Their interface looks very different from the default one, and I was wondering:
Did they achieve this level of customization directly on top of ONLYOFFICE?
If yes, is it possible for other companies to completely change the UI in a similar way, even with an Enterprise plan?
Hello @TIbalt
Please bear in mind that this forum is related to ONLYOFFICE products only, and we cannot check or discuss third-party apps. According to your screenshot, this appears to be a different editor.
With the different versions of ONLYOFFICE (Community, Enterprise, Developer Edition, etc.), is it possible to completely customize the UI?
I know that some light modifications are available depending on the plan, but are more advanced UI changes (like a full redesign) technically possible?
