iPad keyboard text selection does not work
ONLYOFFICE Mobile: Documents / Projects / Web Editors
Do you want to: Report a bug
Device: iPad Pro M4
OS version: 26.3
App version: Latest
Mode: On Device
Additional information:
When trying to select text with the magic keyboard on iPad pro, it does not select with the trackpad as expected like a computer. You have to first select a word and then grab the handles to select a sentence. Not expected behavior. I assume they are not using the proper API for this.
Hi, thank you for the report!
Could you please record a short screen video showing the exact steps and what happens when you try to select text with the Magic Keyboard trackpad (and what behavior you expect instead)?
This will help us clearly understand the scenario and investigate the issue properly.
(If you face a size limit, then you can upload your video to any cloud storage and share a link to it.)
Video
Hi. I just expected it to work with the trackpad like pages or a traditional mac does. Holding down on the trackpad and dragging usually highlights text but doesn’t work in ONLYOFFICE.
Hi, thank you a lot for the video and the additional details!
We’re already looking into this behavior on our side and investigating the situation. We’ll keep you updated in this thread as soon as we have any news.
Hello, thank you for your patience.
We’ve registered a bug for this behavior and are working on a fix.
Unfortunately, we don’t have an exact ETA at the moment, but we’ll update this thread as soon as we have any news.
