iOS save Excel file not possible
ONLYOFFICE Mobile: Documents
iOS version: 18.5
App version: 8.3.2 (1078)
Mode: Connect to ONLYOFFICE WEB Space
After editing an Excel file on my iPhone 15 pro max or my iPad 12.9 pro I can’t safe the file. After confirming “SAFE” the app crashes.
On my Windows 11 PC an my Android smartphone it works well without an issue.
It seems to be a problem on Apple devices only.
Hey @MonacoRR
Thank you for your report! :hugs:
From your description, this might be a new issue, though possibly related to a previously observed one. A new version of the ONLYOFFICE Documents app for iOS is expected to be released later this week and may already contain a fix for this behavior.
If the problem persists after the update, or if you find a consistent way to reproduce it, a screen recording would be very helpful for further investigation.
I’ll make sure to notify you once the updated app becomes available on the App Store. Thanks again for your feedback! :smiley:
Today I had the issue again.
After editing the file and confirmation wir “safe” the app crashed.
Now I’m waiting on the next update.
Hi @MonacoRR
The ONLYOFFICE Documents mobile app has been updated to version 9.0.2 for both iOS and Android .
