ONLYOFFICEhavehave desktop installed on Mac, downloaded app on iPad 10th generation 18.62, I put in the email address and it says connecting, then get a time out message Mobile: Documents / Projects / Web Editors
Device:
OS version:
App version:
Mode: Connect to Cloud / On Device
Additional information:
Any relevant details about the situation. You can also attach images and videofile to the post (or to place them to external storage)
Didn’t type above
Have the desktop version downloaded on my Mac, downloaded the app on my iPad 10th generation, 18.2, put in the email address and it says connection, spins for a while and then get a time out message
Hello @Loopylynn77
Please record a video file with the issue demonstration. Do I understand it right that you’re trying to connect the app with your DocSpace portal or some DMS?
