Hello - I’ve been an avid user now for over a year and recently started using a secondary display for my laptop. I’ve tried to sear for this topic and couldn’t find one, therefore starting one.
If it matters I’m on debian trixie with gnome desktop.
Current
the interface scaling doesnt take into account the screen resolution, it’s a set variable, meaning the ui will look small, or giant, depending on the user settings. Not problem, it can be adjusted through the Interface Scaling.
e.g. my screen resolution is 2880x1800, and OnlyOffice scaling set to 200%.
Problem
Whenever I connect a second display, and the second display is a different resolution, onlyoffice will not be usable, the ui will be giant.
Only fix is to manually set the scaling back.
Solution
Onlyoffice should consider the user’s screen resolution and adjust accordingly, while also allowing use preference Interface Scaling.
