Integration with local AI services
Hello, I have the latest version, the first thing I did was try to update.
Version: 3.2.1
What other data can I provide to make the solution easier?. As I mentioned before, I had managed to get it working, but I don’t specifically remember which version of OnlineOffice it was. Best regards
Without a reproducible scenario I don’t think it’d be possible to determine the cause. Anyway, I’m glad to know that it works now.
I’ll close the topic for now, because most of the AI models are supported. If anyone faces an issue, they should start a new topic.
