Inline editor cursor and pagination issues
Do you want to: Report a bug
Document Server version: Docs API 8
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS:
Browser version:
Additional information:
Issue # 1
When editing a document inline the cursor is clicking on the wrong line.
Issue # 2
The Inline Editor suddenly scrolls down when you highlight or left-click a word on another page.
If you highlight text on Page 3 and then scroll up to Page 2 and attempt to click on any of the toolbar options, it will result in you being scrolled past the Inline Editor to the notes section.
This issue occurs if you highlight text as well as if you use your mouse and left-click next to a word on a page, let’s say on Page 2, and scroll to another page, let’s say on Page 1.
Then suddenly the page will scroll you halfway down.
The problem sometimes is triggered when you highlight a word or left-click next to a word on Page 2 and attempt to scroll up to Page 1.
Hello @ramonajackson
Do I understand that you are using Docs version 8.x.x? If so, please note that this version is outdated, current latest version is 9.3.1. I’d recommend updating your instance, because previously there were issues with cursor misposition.
In case my understanding about the used version is incorrect please specify the version and share some video references of both described behaviors.
