Improvment for viewing presentations
ONLYOFFICE Mobile: Documents
Do you want to: Suggest a feature
Device: Motorola Edge 40 Neo
OS version: Android 15
App version: 9.3.1
Mode: On Device
Could You please add option change the grid size in preview in Presentation or making the presentation app more convenient for just viewing?
Here is my specific use case:
I often quickly look at presentations just to see the content etc, on PowerPoint Mobile when you open file you get a list of all slides (and button to edit at the bottom) , but in the OnlyOffice only one slide is visible and to look for others you have to manually change slides at the bottom, which can be slow and moving finger through edges can cause situation of moving object on the slide (37 second of the video).
VIDEO
As a quick improvment I was thinking about option to change the grid, so that user can set one slide per row (as with 2 it’s hard to see a text and content on the phone) - this is just my suggestion, if you have a superior solution that even better
PREVIEW
PS
Turning presentation mode is not always a solution, as slides tend to have transitions that simply takes a lot of time.
If something is unclear or you have additional questions please feel free to contact me :slight_smile:
Hello, @Bono !
Thank you for your detailed suggestion and the examples you provided — this is really helpful for understanding your use case.
We’ve forwarded your proposal regarding a more convenient slide overview/grid customization in the mobile presentation viewer to our QA team for review. Once there are any updates or decisions on implementation, we will post them here in this thread.
Thank you again for your suggestion and for the detailed explanation.
We would like to let you know that based on your feedback, we have now created an internal bug report for this behavior so our team can investigate possible improvements to presentation viewing on mobile devices.
At the moment, we do not have an exact ETA, but we will update this thread as soon as there is any progress or news.
