Improve trackpad zooming
The zoom-in functionality when using a trackpad via the “pinch-in / pinch-out” method uses only intervals of 10 to zoom in and out, instead of providing a more gradual single integer zoom. A suggestion has been made back in 2023 Option to customize zoom value in onlyoffice applications(Document, Spreadsheet etc.) the way we want - #4 by Nikolas but it hasn’t been implemented since.
I would argue that this feature would be a positive change for the product, as it makes it easier to keep your focus on the content you’re trying to zoom in on instead of it just jumping in increments of 10.
Another problem that is present with trackpad zooming is the sensitivity of it. The current functionality is extremely sensitive, not requiring that much distance traveled to zoom. This is a problem as getting small zoom-ins can be hard for people.
I’ve found myself needing to zoom in since my laptop screen isn’t always the same distance away from me, and with the document jumping from too much zoom all the way to too little zoom is rather frustrating.
Hello @JoshuaLorenzo
What exactly do you suggest? As I can see, mentioned topic suggests implementing custom values for zoom, which is barely referencing your query.
Essentially it’s 3 things here.
  1. “Custom Values for zoom” but what I really mean by this is just the zoom being able to support uneven values, so 111%, 156%, 83%, should all be values that can be used.
  2. Zooming in (with a pinch gesture on the trackpad) should smoothly zoom in instead of jumping 100% → 110% → 120%. Instead it should be interpolated 100% → 101% → 102% (but obviously sped up)
  3. Less sensitive zooming in gesture for trackpad. The current one is extremely sensitive and zooms too much out or too much in.
is this a better explanation of the issue? Let me know if this is clear enough.
Thank you very much, your description is perfect. Since, first two items depend on each other and there is already a suggestion for uneven values, let’s focus on them in this topic. I will forward these two to devteam.
Kindly asking to start a new topic for this one. It’d help to avoid mixing up several suggestions in a single and allow to search for specific suggestion across the community. Thank you for understanding.
As a follow-up: the suggestion has been registered under the number 79280 in out internal bug-tracker. Thank you for the interest.
