Identification of contributors to suggestion
Imported from UserVoice
Author: Xavier Cousin
In the version I use (in La Suite) I was not able able to find a way to differentiate contributors in suggestion mode so all suggestions have the same colour and beyond this, if you modifiy a suggestion made by someone else, the previous suggestion is deleted as if, independenlty of the contributors, there was only one contributors, this complicates the process.
NB this may be related to the fact that “not connected” contributors all appear as the same anonymous contributor? Whatevever, this is not smoothly managed.
Best
Do you refer to the list of users in collaborative editing mode? You can find it in top right corner next to your avatar.
If I misunderstood your query, please elaborate. You can also provide any screenshots for the reference.
