When I select part of the text in a cell in a spreadsheet from the front and set it to Bold, the “B” button becomes set, and I can press the “B” button to cancel the Bold setting.
However, if I select part of the text in a cell from the back, the “B” button in the menu does not become set even if I set it to Bold, so I cannot cancel the Bold setting with the “B” button.
Please provide a screen recording of the issue reproduction
Hello @DmitriiV
When I select a part of text from the front, then “B” button is set. I can unset by “B” button.
When I select a part of text from the end, “B” button is not set. I can’t unset by “B” button.
Got it, we are currently analysing the issue
We’ve registered the relevant bug. Please wait until the version with the fix is released; we will inform you here
Thanks @DmitriiV
I look forward to the fix.
