How to maintain aspect ratio and load local images with DocBuilder Java SDK?
'm using OnlyOffice DocBuilder Java SDK to programmatically create documents with images. I have two issues:
Auto-height based on aspect ratio: When inserting an image with CreateImage, I want to specify only the width and have the height automatically calculated based on the image’s original aspect ratio. Is this possible, or do I need to manually calculate and provide both dimensions?
Local file path not recognized: I’m passing a local file path to the image, but it doesn’t appear in the generated document.
Questions:
Do I need to convert local images to base64 or URL format?
What’s the recommended approach for loading images from the local filesystem in DocBuilder?
Any help would be appreciated!
Hello @Aygun
Please do not post the same request in different communication channels. As far as I understand, you are already communicating via Zendesk with the same request.
We will post the final result in this thread once the case is resolved in Zendesk.
I understand. I wanted to clarify that this question was posted before my inquiry on Zendesk received a response. Currently, the discussion is ongoing on that platform, and we are continuing the process there.
Thank you for the information.
Hey @Aygun, :wave:
Totally agree — if you have a license and can use Zendesk, the support team there can respond much faster. Here on the forum, we do our best, but it’s not always instant.
Either way, thanks for understanding and for the patience!
