How to expose document server over https installed on vps
this is my nginx ds.conf i get port issues because ports are already is use and nginx does not start.. what to do so that i can access this server from anywhere to be used in my projects
Redirect HTTP (port 80) to HTTPS
server {
listen 80;
server_name cora.us.com;
return 301 https://$host:8443$request_uri;
Main HTTPS server
server {
listen 443 ssl;
ssl_certificate     "C:/Program Files/ONLYOFFICE/DocumentServer/nginx/certs/cora.us.com.crt.pem";
ssl_certificate_key "C:/Program Files/ONLYOFFICE/DocumentServer/nginx/certs/cora.us.com.key.pem";
ssl_protocols       TLSv1.2 TLSv1.3;
ssl_ciphers         HIGH:!aNULL:!MD5;
location / {
    proxy_pass http://127.0.0.1:8085;
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection keep-alive;
    proxy_set_header Host $host;
    proxy_cache_bypass $http_upgrade;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Proto $scheme;
if i change the ports to others i get ssl issues it will be helpfull if someone could help me complete this setup because of this my project is on hold. and i have no experience with this before
Hello @Rashid
Did you install ONLYOFFICE Docs (Document Server) according to the official guide?
Do I understand correctly that there is another app that occupies ports 80 and 443?
By the way, the guide for switching Document Server to HTTPS is also available:
However, I must ask – do you use any proxy service in front of Document Server for port forwarding? Or do you expose ports directly on the server?
