Please describe your suggestion as detailed as possible. You can also draw a scheme or attach images and videofile to the post (or to place them to external storage).
I want to change the standard font Arial into Minion Pro. For good. But it seems to mee it is not so simple as it looks like. Can anyone help me with this issu? If find it rather difficullt. Thank you very much in advance!
