How can i remove AI
Hello, im just wondering how i can remove both the AI and DeepL plugins. I dont want them. If possible, id like to know how for both windows and linux as I use onlyoffice on both.
Hello @mayar,
To remove the AI and DeepL plugins, delete the following folders:
Linux:
/var/www/onlyoffice/documentserver/sdkjs-plugins/{9DC93CDB-B576-4F0C-B55E-FCC9C48DD007}
/var/www/onlyoffice/documentserver/sdkjs-plugins/{b78a062b-e349-4634-8a44-99825600d299}
/var/www/onlyoffice/documentserver/sdkjs-plugins/marketplace
Windows:
C:\Program Files\ONLYOFFICE\DocumentServer\sdkjs-plugins{9DC93CDB-B576-4F0C-B55E-FCC9C48DD007}
C:\Program Files\ONLYOFFICE\DocumentServer\sdkjs-plugins{b78a062b-e349-4634-8a44-99825600d299}
C:\Program Files\ONLYOFFICE\DocumentServer\sdkjs-plugins\marketplace
After deleting these folders, clear your browser cache.
Hello, thank you but i dont have a documentserver/ folder, just desktopeditors/
im using the desktop app
Hi @mayar,
Thank you for the clarification.
Since you are using the Desktop Editors, please look for the folders in the following locations depending on your OS and installation method.
Windows Delete the following folders: C:\Program Files\ONLYOFFICE\DesktopEditors\editors\sdkjs-plugins\{9DC93CDB-B576-4F0C-B55E-FCC9C48DD007}
C:\Program Files\ONLYOFFICE\DesktopEditors\editors\sdkjs-plugins\{b78a062b-e349-4634-8a44-99825600d299}
Linux (DEB/RPM) Delete the following folders: /opt/onlyoffice/desktopeditors/editors/sdkjs-plugins/{9DC93CDB-B576-4F0C-B55E-FCC9C48DD007}
/opt/onlyoffice/desktopeditors/editors/sdkjs-plugins/{b78a062b-e349-4634-8a44-99825600d299}
Linux (Snap) If you installed via Snap, the paths are located here: /snap/onlyoffice-desktopeditors/current/opt/onlyoffice/desktopeditors/editors/sdkjs-plugins/
After deleting these folders, please restart the desktop application.
Is there a way to do this on a Samsung smartphone?
Hello @hurricanejohn
Do you mean the android app ‘ONLYOFFICE Documents’?
No i want to keep the app just remove the AI like i did on my windows and linux installs
Understood, we are checking the situation. I will contact you as soon as possible.
Dear @hurricanejohn
We have added your request to internal tracksystem (internal tracknumber - 79215). We will contact you once we have something to share.
