HOJAS CON COLOR SOLIDO ( EN EL RECUADRO ) / SHEETS WITH SOLID COLOR (IN THE BOX)
Imported from UserVoice
Author: Sebastian BS
A demas de que se puedan ocultar las hojas y del tema de los hipervinculos , seria genial que cuando le asignas un color , pinte el recuadro completo asi es visualmente facil de identificar rapidamente , desde ya se agradece que la barra de despalzamiento este arriba asi podes ver un mayo espacio con cada hoja //
Besides the ability to hide sheets and the hyperlink issue, it would be great if, when you assign a color, it painted the entire box so it’s visually easy to identify quickly. It’s also appreciated that the scroll bar is at the top so you can see more of each sheet.
Author: Alexander Skorniakov
When you set a color for a sheet tab, it would be great to have an entire tab filled with this color, not just a thick line at the top. Much easier to navigate through multiple sheets then
