Highlight text from collaborator editing
OS version: MacOS Big Sur 11.7.10
App version: ONLY OFFICE 9.1.0
When I’m working with a collaborator in the same word document, every time my collaborator write something the text will appear highlighted with his color in my computer.
This does not happen to my collaborator computer.
If my collaborator close the document and I re-open it , the highlight color goes away.
I’m sure there is an option to change this feature, but I cannot find it
I attached a screenshot from my computer.
Thanks
Hey @beppe, :wave:
I think the Track Changes feature is enabled for you:
  • Off for me — tracking changes is disabled for the current user only. The option remains disabled for the current editing session. It will not be affected by other users enabling or disabling the general tracking changes option.
https://helpcenter.onlyoffice.com/docs/userguides/document_editor/review.aspx
Take a look — experiment with it :wink:
I did all test with all reviewing settings. But I still have this problem.
One particularity is that if, with the account that I have problems, I log to another computer, the problem is gone.
It’s very strange since I’m using the same macOS Big Sur 11.7.10 and the same Only Office version 9.2.0
Beppe
Hello @beppe
First of all, you are using outdated version of Desktop Editors, I recommend updating it.
Secondly, it is not clear which storage is connected to Desktop Editors. Can you elaborate from which source the files is opened?
