Hide deleted elements
ONLYOFFICE Mobile: Documents
Do you want to: Suggestion
Device: Motorola Edge 40 Neo
OS version: Android 14
App version: 9.0.2
Mode: Connect to Cloud
While browsing files in the OnlyOffice apps, it shows deleted elements - is this expected behaviour?
All this .trashed are elements that were deleted (and for 30 days they are in the trash) - at least in my opinion they shouldn’t be displayed, as it creates quite a big mess and complicates the process of finding desired file.
On the attached screenshot above only one file is not deleted (in the trash).
Best Regards,
dedoci
Hello, we are currently checking, please wait
How did you delete these files? Did you use Google Files?
Yes, I am using Google Files and deleted those files using “delete” option withing mentioned app.
If files are deleted through third-party file managers, some of them may leave the file in such a state. Google Files does this, for example.
Unfortunately, there’s nothing we can do on our side.
Sure, I understand that you don’t have any impact on the fact that Google Files create such temporary files, but is it perhaps possible to just add some if statement that if file starts from .trashed then do ignore displaying it?
All this trashed elements are making the process of finding correct files quite difficult.
Thanks for your thoughts, we will analyze this suggestion
