Hi everyone,
I noticed OnlyOffice was missing a nonlinear programming solver, so I built one.
GitHub: GitHub - Karl1b/only-office-nlp-solver: NLP Solver plugin for OnlyOffice Spreadsheet. Optimizes a target cell by adjusting parameter cells within bounds using numerical nonlinear programming (Go/WebAssembly). Keywords: NLP, solver, optimization, OnlyOffice plugin, spreadsheet, nonlinear programming, WebAssembly, Go, parameter fitting, minimization. · GitHub
The repo includes an example spreadsheet with two real-world optimization problems and the Himmelblau function as a test case.
A and the download of course, I can not share the link directly here. Cause I am a new user
I’m planning to submit this to the plugin marketplace later, but still this year, and your feedback would really help shape the final version. Specifically, I’d love to hear:
- What optimization problems are you solving? (Always looking for edge cases to test)
- How does it compare to Excel Solver or LibreOffice Calc on your data?
- What’s missing, broken, or could be better?
Looking forward to hearing what you think!
Karl karlbreuer.com
The solver now supports side conditions and is basically ready for the store.
Just some polishing left.
Project page here:
- Still open for feedback
The solver now has a new mode that can also fit the function itself by brute forcing polynoms.
Hello @KarlBreuer
We’ll review your plugin. I’ll contact you once we have something to share.
Hi Alexandre,
thanks, but this is not really needed.
What I would appreciate is if you could fix the plugin manager / loader.
There is definetely bug, but the greater issue is that there is no error logging with correct stacktrace so the bugs and or mistakes are hard to spot and fix.
Thanks and KR
Karl
How the behaviour is:
- start oo with console
/usr/bin/desktopeditors --ascdesktop-support-debug-info
- open the dev tools, by clicking on some specific fields
- produce the error, for example by loading a plugin.
- There is only the message that there was an error, but not what and where it came from.
OUTPUT:
code.js:1233
Error: Problem with plugin installation.
at code.js:1635:16
at index.html?lang=en-US&theme-type=dark:1:22
at index.html?lang=en-US&theme-type=dark:1:167
createError @ code.js:1233
(anonymous) @ code.js:1635
(anonymous) @ index.html?lang=en-US&theme-type=dark:1
How the behaviour should be:
4. should be a complete error object with stacktrace and lots of info of what went exactly wrong and where. This will help fix bugs in the future and frankly this should be standard in all places as it makes life ez for us devs
Hello @KarlBreuer
Sorry for the late reply.
Does the issue still occur in the latest Desktop App version 9.4?
@Alexandre
No, nothing changed. The error message is without any info.
This is where it comes from:
window["AscDesktopEditor"]["OpenFilenameDialog"]("plugin", false, function (_file) {
var file = _file;
if (Array.isArray(file))
file = file[0];
let result = window["AscDesktopEditor"]["PluginInstall"](file);
if (result) {
// need to update the list of installed plugins
sendMessage({ type: 'getInstalled', updateInstalled: true }, '*');
} else {
createError(new Error('Problem with plugin installation.'), false);
Hello @KarlBreuer
Do I understand correctly that you are installing a plugin manually from .plugin file? I have downloaded your plugin as ZIP archive from the repo in original post, changed the extension to .plugin, and then installed it - didn’t receive such error.
Did I miss anything?
