When editing the GRP function through a dialog box or function arguments, the document freezes. You can close it without changes, but if you try to close it, the hang can only be eliminated by closing the document through the task manager.
Hello @Maxim
Does it happen with a particular file or even in a new one? By the way, please provide information about used app and the version of it. Do you use Desktop Editors?
The problem occurs in both the new and the old file. Perhaps the reason is the large number of formulas on the page.
I am attaching a photo of the version (9.0.3.29).
It is also noticed that after removing the task in the task manager, the file editosr_helper.exe it does not stop working, which heavily loads the system.
Is it possible to share a demo file for analysis?
Please leave your comment here:
