For feature suggestions, describe the result you would like to acieve in detail:
Community Server/Control Panel version:
Type of installation of Workspace (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS:
Browser version:
Additional information:
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
Hello @Link28,
Could you please describe your question about Google Drive integration? Your post currently contains only the unfilled template.
Please let us know which ONLYOFFICE product and version you are using and what you would like to achieve. If something is not working, please describe the steps you take and what happens, including any error message or a screenshot.
