Folder size and graphical representation
Imported from UserVoice
Author: orbit21
Feature Suggestion: Folder Size & Storage Visualization Dashboard
I would like to suggest adding a Folder Size and Storage Visualization feature to the Onlyoffice DocSpace.
Currently, it is difficult to determine which folders are consuming the most storage space. A visual and analytical view would greatly improve storage management and efficiency.
Proposed Features:
  1. Folder Size Display
    • Show the total size of each folder directly in the file explorer view.
    • Display subfolder sizes recursively.
  2. Graphical Storage Representation
    • Provide a visual dashboard with:
      • Pie chart or donut chart showing storage distribution by folder.
      • Tree map view for hierarchical space usage.
      • Bar chart for top 10 largest folders/files.
  3. Large File Identification
    • Dedicated section for:
      • Largest files (sortable by size).
      • Files above a user-defined threshold (e.g., >100MB).
      • Duplicate or rarely accessed large files.
  4. Drill-Down Capability
    • Clickable charts that allow users to navigate directly to large folders/files.
    • Expandable tree structure to identify exactly where storage is being consumed.
  5. Storage Insights Panel
    • Summary metrics such as:
      • Total used vs available space.
      • Percentage usage by category (Documents, Media, Backups, etc.).
      • Alerts for unusually large uploads.
Benefits:
  • Helps users quickly identify storage-heavy folders.
  • Simplifies cleanup and optimization.
  • Improves transparency in space utilization.
  • Saves time when managing large cloud environments.
This feature would significantly enhance user control and visibility over their cloud storage usage.
Thank you for the suggestions. To keep it right, please submit each of five ideas in this topic separately. This would help us tracking the progress on each item individually.
Simply go to Suggestions DocSpace subcategory and use + New Topic button to start new topics. To keep it clear, please add relevant tags too.
Thank you for understanding.
