Filter() function bug
OS version:
App version:
Downloaded from: ONLYOFFICE website / Other (specify). Please point us to the installation guide that you used as well.
Additional information:
Any relevant details about the situation. You can also attach images and videofile to the post (or to place them to external storage).
[UPDATED]
according to the documentation, the Filter() function is an array operation that requires us to select a fixed target range and use the ctrl-shift+enter sequence.
when the instructions for arrays are applied, the FILTER function sometimes produces an error.
if the results of the filter only contain a single row, that row will be repeated across the entire destination range. text strings produced the same error.
Hey @anthony_c :wave:
Thank you for your detailed explanation and for providing the examples.
We have checked the described behavior, and we can confirm that the FILTER() function in ONLYOFFICE currently works as a classic array formula (similar to Excel before Dynamic Arrays were introduced).
At the moment:
  • ONLYOFFICE does not yet support dynamic (spilled) arrays.
    Because of this, FILTER cannot automatically expand its output range based on the number of results.
  • The user must manually select a fixed output range before confirming the formula with Ctrl+Shift+Enter.
  • When the selected output area is larger than the actual number of filtered values, the spreadsheet engine fills the remaining cells according to the rules of traditional array formulas:
    • a single-row result may be repeated to fill the entire array, or
    • unused cells may display #N/A.
This is expected behavior in the current implementation and not an error in the FILTER() function itself.
The good news: :upside_down_face:
Dynamic arrays are planned for future versions of ONLYOFFICE
the implementation of dynamic arrays would be a very welcome addition, and not a moment too soon!
while the static arrays are “functioning as designed”, they are difficult to work with and produce many errors. the work-arounds have already consumed a few weeks worth of effort just to re-tool a single spreadsheet.
i still feel that repeating rows when there is only one array element qualifies as a defect. that does not happen when there are only 2 array elements.
thanks in advance,
ac
