Filebrowser quantum (Docker)
ONLYOFFICE Mobile: Documents / Projects / Web Editors
Hi, is possible to connect with my self-hosted onlyoffice using filebrowser quantum?
I tried the android app version but only works with nextcloud, owncloud, kdrive, onedrive, dropbox and webdav, i tried with webdav but didn’t work.
Device:
OS version: Synology DSM 7.1
App version: Android 9.2.0
Mode: Connect to Cloud / On Device
Additional information:
Onlyoffice is working well and i can create and edit files through the webbrowser via filebrowser quantum in the desktop.
Hello @javikobcn
What exactly have you tried?
Are you hosting Document Server that is integrated with a WebDAV storage?
Hi, i used this guide for the installation:
This integration was developed by FileBrowser Quantum team. Does it have regular WebDAV support?
Also, I am still looking forward to this information:
Sorry, I hasn’t explained well. I tried the WebDAV login in Android app but obviously didn’t work because in my server is not configured for webdav
The documentation that you have provided describes how to start Filebrowser Quantum with Document Server in Docker. This setup does not assume working from the mobile app, because Filebrowser Quantum apparently does not work with WebDAV at all.
