ONLYOFFICE Desktop Editors
Community version 9.3.1.8 (arm64 exe)
How do I find out efficiently which feateres are available for the Desktop Editor versions? Right now I’m trying to print or convert and print a MD document but thisseems not applicable. I can edit but not print or convert the result in PDF
You can find general information about ONLYOFFICE Desktop Editors in our Help Center here: ONLYOFFICE Desktop Help Center.
As for supported formats, please refer to this table: Supported formats of electronic documents.
Markdown files should be convertible to PDF and printable as well. I have also checked this behavior on my side, and it works correctly.
Could you please share the Markdown file you are testing so we can check the behavior on our side as well?
Also, please let us know the exact version of ONLYOFFICE Desktop Editors you are using.
