ONLYOFFICE Docs (Document Server) allows controlling how much information to print to logs — for example, to troubleshoot performance issues, inspect logs, or collect information for support. In this guide we will cover all information about the levels that Document Server offers under the hood and how to change them.
Let’s start with basic info:
Locations of logs
The logs are stored in the following locations (depending on the installation type):
- For Windows -
C:\Program Files\ONLYOFFICE\DocumentServer\Log; - For Linux -
/var/log/onlyoffice/documentserver; - For Docker -
/var/log/onlyoffice/documentserver(within the Docker container) and/app/onlyoffice/DocumentServer/logs/documentserver(on the host if you mount the volume).
Note: these are default paths, if changed, please refer to set up location.
In all of these paths you can find /docservice and /converter folders that contain out.log files with actual logs. Everything related to opening and conversion processes is located under /converter folder, obviously; /docservice bears the rest of information.
Logging levels you may find
Document Server prints following levels to logs:
WARN– Normal workflow, sometimes shows when something is off.DEBUG/TRACE– Internal behavior. These explain how the application operates, including occurred errors. They’re usually off in production.INFO– Business-as-usual. If everything is healthy, most of your logs live here.ERROR– A failure occurred. This should be actionable and measurable.FATAL– Your application is about to terminate due to an unrecoverable error.
Basically, all of these levels display the state of an operation and/or the application itself. However, depending on the level used, not every level gets printed, please refer to the table below:
| Configured level | What gets emitted |
TRACE |
TRACE, DEBUG, INFO, WARN, ERROR, FATAL |
DEBUG |
INFO |
WARN (default) |
ERROR |
ERROR, FATAL |
FATAL |
FATAL only |
You can set up necessary level from the table above to make Document Server include specific levels to the logging flow for your information.
Changing logging level in Document Server
You can change the logging level to any of those we’ve described earlier, however, in most cases you need either default WARN or DEBUG levels. We’ll demonstrate how to set everything up to print all logs in debug mode.
Using Docker
If you are using Docker as the installation type for your instance, you can set up logging level beforehand with environment variable DS_LOG_LEVEL.
For instance, running a Docker container with docker run:
docker run -i -t -d -p 8080:80 \
-e DS_LOG_LEVEL=DEBUG \
onlyoffice/documentserver:latest
Or using Docker Compose:
- Set the environment variable in
docker-compose.ymlwhen running the container:
services:
documentserver:
image: onlyoffice/documentserver:latest
container_name: documentserver
restart: always
environment:
- DS_LOG_LEVEL=DEBUG
ports:
- "8080:80"
- Start Docker Compose:
docker-compose up -d
Using the log4js configuration file
- Open the log4js configuration file. The path to the file depends on the operating system you use:
- For Windows -
C:\Program Files\ONLYOFFICE\DocumentServer\config\log4js\production.json - For Linux -
/etc/onlyoffice/documentserver/log4js/production.json - For Docker -
/etc/onlyoffice/documentserver/log4js/production.json(within the Docker container)
- Refer to the following code block:
"categories": {
"default": {
"appenders": [
"default"
"level": "WARN"
- Change the
levelvalue from"WARN"to"DEBUG"; - Save the changes in the
production.jsonconfiguration file; - Apply the changes executing the following command:
- Linux
systemctl restart ds-*; - Docker
supervisorctl restart all; - Or restart the ONLYOFFICE DocumentServer Proxy service for Windows:
net stop DsProxySvc
net start DsProxySvc
net stop DsConverterSvc
net start DsConverterSvc
net stop DsDocServiceSvc
net start DsDocServiceSvc
What is that for?
Changing the logging level controls how much information Document Server records. Use a lower level such as TRACE or DEBUG when investigating a problem and you need more detail; use WARN or ERROR when you mainly want to see potential or actual problems. In short, the logging level lets you balance useful diagnostic information against log volume and noise.
Note:
DEBUGandTRACEare much more verbose thanWARN. Enable them only while investigating, then switch back toWARN.
