Error when using text for a scanned document to PDF format
It’s worth improving the way text is added to files exported to PDF. Currently, if you scan a document to PDF and add text to it, the document loses its integrity when printed. The same happens when saving to disk. When you reopen the file, it’s a complete mess.
Hello @Rafal
Can you provide more details? In particular:
  • How do you add text exactly?
  • Does it happen with any scanned PDF?
  • How resulting PDF is saved?
Any PDF samples (original PDF before adding text and resulting PDF with a text) would be much appreciated.
Also, please specify product that is being used (Desktop Editors/Docs) and its version.
