Hi
I have an SSL issue, have newly installed ONLYOFFICE_Workspace_Win 24.12, changed settings in Control panel to
Document editing addr: ds-vpath
Document service addr for req. from Community server: https://myserver.local:8083/
Community server addr for req. from Document server: https://myserver.local/
and copied ds-ssl.conf.tmpl to ds.conf (added my crt & key into),
so ds.conf now looks as shown below.
But now I can open only https://myserver.local/welcome
Trying to open smth like https://myserver.local/controlpanel/backup Control Panel says:
Cannot GET /controlpanel/backup
Or Cannot GET /ds-vpath
(Console: Failed to load resource: the server responded with a status of 404 (Not Found)
What have I missed and what have to be done?
Thank you.
include includes/http-common.conf;
## Normal HTTP host
server {
listen 0.0.0.0:80;
listen [::]:80 default_server;
server_name _;
server_tokens off;
set $secure_link_secret e8mymMnNsALzrBYfbIt2;
## Redirects all traffic to the HTTPS host
root /nowhere; ## root doesn't have to be a valid path since we are redirecting
rewrite ^ https://$host$request_uri? permanent;
#HTTP host for internal services
server {
listen 127.0.0.1:80;
listen [::1]:80;
server_name localhost;
server_tokens off;
include includes/ds-common.conf;
include includes/ds-docservice.conf;
## HTTPS host
server {
listen 0.0.0.0:443 ssl;
listen [::]:443 ssl default_server;
server_tokens off;
root /usr/share/nginx/html;
ssl_certificate "C:\\Program Files (x86)\\Ascensio System SIA\\DocumentServer\\nginx\\certificates\\local.cer";
ssl_certificate_key "C:\\Program Files (x86)\\Ascensio System SIA\\DocumentServer\\nginx\\certificates\\local.key";
ssl_verify_client off;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH";
ssl_protocols TLSv1.2;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_prefer_server_ciphers on;
add_header Strict-Transport-Security max-age=31536000;
# add_header X-Frame-Options SAMEORIGIN;
add_header X-Content-Type-Options nosniff;
include includes/ds-*.conf;
(at the end I’ve run secrets updater .bat)
