Elastic search in Workspace won't start on fresh install. Muliple tries
BUG
For feature suggestions, describe the result you would like to achieve in detail:
Get elastic search in Workspace community working. It fails to start
Community Server/Control Panel version:
Install with script any community workspace
onlyoffice/documentserver:9.0.4.1
onlyoffice/communityserver:12.7.1.1942
onlyoffice/controlpanel:3.5.4.541
onlyoffice/mailserver:1.6.75
onlyoffice/elasticsearch:7.16.3
mysql:8.0.29
Type of installation of Workspace (docker, deb/rpm, exe, please point us to the installation guide that you used as well): Docker with install script including Mailserver
OS: Ubuntu 24.04LTS
Browser version:
Additional information:
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
docker logs for elastic search
	at java.base/jdk.internal.platform.cgroupv2.CgroupV2Subsystem.getInstance(CgroupV2Subsystem.java:81)
	at java.base/jdk.internal.platform.CgroupSubsystemFactory.create(CgroupSubsystemFactory.java:113)
	at java.base/jdk.internal.platform.CgroupMetrics.getInstance(CgroupMetrics.java:167)
	at java.base/jdk.internal.platform.SystemMetrics.instance(SystemMetrics.java:29)
	at java.base/jdk.internal.platform.Metrics.systemMetrics(Metrics.java:58)
	at java.base/jdk.internal.platform.Container.metrics(Container.java:43)
	at jdk.management/com.sun.management.internal.OperatingSystemImpl.<init>(OperatingSystemImpl.java:182)
	at jdk.management/com.sun.management.internal.PlatformMBeanProviderImpl.getOperatingSystemMXBean(PlatformMBeanProviderImpl.java:280)
	at jdk.management/com.sun.management.internal.PlatformMBeanProviderImpl$3.nameToMBeanMap(PlatformMBeanProviderImpl.java:199)
	at java.management/java.lang.management.ManagementFactory.lambda$getPlatformMBeanServer$0(ManagementFactory.java:488)
	at java.base/java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:273)
	at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:179)
	at java.base/java.util.HashMap$ValueSpliterator.forEachRemaining(HashMap.java:1779)
	at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499)
	at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
	at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
	at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:596)
	at java.management/java.lang.management.ManagementFactory.getPlatformMBeanServer(ManagementFactory.java:489)
	at org.apache.logging.log4j.core.jmx.Server.reregisterMBeansAfterReconfigure(Server.java:140)
	at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:637)
	at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:302)
	at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:209)
	at org.apache.logging.log4j.core.config.Configurator.initialize(Configurator.java:243)
	at org.apache.logging.log4j.core.config.Configurator.initialize(Configurator.java:219)
	at org.elasticsearch.common.logging.LogConfigurator.configureStatusLogger(LogConfigurator.java:251)
	at org.elasticsearch.common.logging.LogConfigurator.configureWithoutConfig(LogConfigurator.java:95)
	at org.elasticsearch.cli.CommandLoggingConfigurator.configureLoggingWithoutConfig(CommandLoggingConfigurator.java:29)
	at org.elasticsearch.cli.Command.main(Command.java:74)
	at org.elasticsearch.common.settings.KeyStoreCli.main(KeyStoreCli.java:33)
Exception in thread "main" java.lang.NullPointerException: Cannot invoke "jdk.internal.platform.CgroupInfo.getMountPoint()" because "anyController" is null
	at java.management/sun.management.spi.PlatformMBeanProvider$PlatformComponent.getMBeans(PlatformMBeanProvider.java:195)
	at java.management/java.lang.management.ManagementFactory.getPlatformMXBean(ManagementFactory.java:687)
	at java.management/java.lang.management.ManagementFactory.getOperatingSystemMXBean(ManagementFactory.java:389)
	at org.elasticsearch.tools.launchers.DefaultSystemMemoryInfo.<init>(DefaultSystemMemoryInfo.java:29)
	at org.elasticsearch.tools.launchers.JvmOptionsParser.jvmOptions(JvmOptionsParser.java:125)
	at org.elasticsearch.tools.launchers.JvmOptionsParser.main(JvmOptionsParser.java:86)
When I inspect the docker container it seems to be not starting with proper jvm options listed in the community server.
ES_JAVA_OPTS=-Xms4g -Xmx4g -Dlog4j2.formatMsgNoLookups=true
are the jvm options loaded and I can’t seem to reset this.
I reinstalled everything with docker compose and restored from backup and it is now working.
