Hi, newbie here, so apologies in advance if this topic has already been covered…
I’ve just installed OO 9.0.4 on my Mac M3 laptop, and I can’t seem to get the Edit menu functions to work as expected.
If I use the menu option Edit…Select All, the body text in the document that I’m working on isn’t selected. The Edit…Copy function doesn’t copy the text as a result.
I can use the keyboard commands to select the data – CMD-A, CMD-C, etc. , but the menu options flat out refuse to work for me.
No such issues with LibreOffice or Textpad, for example, using the same functions. It’s just OO that doesn’t want to play.
Am I doing something stupid, being new to the software, is it a bug, or something else? I’ve checked the available settings and can’t see anything obvious that would cause this issue.
Cheers, Clem
