Is it also possible to convert a document file to PDF format directly from the OnlyOffice word processor? Why isn’t it working for me? I’m not getting a finished file that opens directly in the OnlyOffice PDF viewer.
Hi @brinkie1966!
It should work via File → Save as → PDF. Could you tell us which ONLYOFFICE product you’re using, the version, and what exactly happens when you try it?
OnlyOffice 9.4.0.129
Windows 11 - 26H 26300.9711
First of all, thank you very much for your response. I really appreciate it!
I see that there are two optioneel for exporting a file to Pdf. I need the second optioneel, Pdf/A. That way, I do get a file.
By the way, is it true that you can’t open this file directly in the OnlyOffice Pdf viewer? Without leaving the OnlyOffice word processor?
Thank you for redding this.
Please response.
