When I share a file from Excel 2016 via Nextcloud and open it in OnlyOffice online, the data validations do not work properly. I have to validate them one by one for them to function. Otherwise, I cannot enter any data into the cells.
Hello, this is the file, you can try in the sheet CAPa1 A for exemple to erase a number data end try to write it again. the data validation avoid the try, if you validate the data validation, it’s become OK
