CSV format changed on save
If I open a csv format document with field-separator “;” and save the same document it is changed to field- separator “,” without comment.
Is this behaviour by design or is this a bug?
Hello @theking2
Please share a test sample, we will check it out.
123456.csv (51 Bytes)
Thank you for the file!
Open the file and resave it in the same (csv) format. It seems to be expected behavior, there is a notification about feature loss.
Not true. It will replace the ; by ,
We’re discussing this case internally, I will contact you as soon as possible.
Hello @theking2
We have added your request to internal tracksystem (36923), we’re working on it already.
We will update this thread once we have something to share.
