Hi. Thank you for assisting me.
I have this installed and have enabled the admin console. If you could create better documentation on where to find the code, that would be great. I am versed enough in linux to search through /var/log until I found it.
I have /example/ working. I cannot find any documentation on how to create a new group. I have linked Dropbox.
Hello @arktex54
The Admin panel documentation is available here: Using the Admin Panel for ONLYOFFICE Docs
Please let us know if there’s anything we can improve.
As for the /example/, it’s a little bit unclear. The /example/ is integrated test-sample to verify that Docs is working correctly. We do not recommend using it in production, you need to integrate Docs to stand-alone DMS such as Nextcloud, ownCloud, Seafile, etc. The list of available connector apps is here: Ready-to-use connectors for your platform | ONLYOFFICE
Do I understand it right that you need to ‘create a group’ in the Dropbox integration? Integration Guides - Dropbox - ONLYOFFICE
Please clarify the situation.
