Do you want to: Report a bug
OS version: Windows 11
App version: 9.0.0.172 (x64 exe)
Could you please fix the way how data are copied from Deepseek (possible it impact other services):
Here is sample text generated in Deepseek:
Here it’s after copying to MS Word:
And here it’s after copying to OnlyOffice
At least in my opinion, the MS Word approach is superior here, because even though the background on Deepseek is indeed dark, but in majority cases it isn’t that useful to copy the background as well.
Best regards,
dedoci
Hello @dedoci,
What version of MS Word is being used? I’ve tested it in several editor apps, and the behavior seems consistent across them - the background style is copied as well.
Hello @DmitriiV ,
Thank You for your reply, I thought that approach is the same among on all versions of MS Word.
My version is:
Microsoft Word for Microsoft 365 MSO (Version 2505 Build 16.0.18827.20102) 64-bit
I also checked my copy, paste settings:
And from what I see, everything is default here.
Hey @dedoci
Thank you for the additional details and for checking your MS Word settings!
We’ll get back to you once we’ve analyzed it further. Thanks again!
Hello @dedoci,
Apologies for the delayed response – I was tidying up some threads and missed that this one was still awaiting a reply. Thank you for your patience!
When copying text, its formatting properties are preserved.
In ONLYOFFICE Desktop Editors, the pasted text retains its original formatting (dark background, white letters). In Microsoft Word, the default setting is “Merge Formatting,” which adjusts the pasted text’s appearance to match Word’s style. If you select “Keep Source Formatting” in Word’s paste options (as is default in our editor), the text will also appear with a dark background and white letters.
Thank you for your valuable contribution! If you have further questions, please let us know.
