Copy/Pasting Shapes Issue
OnlyOffice Ver: 9.3.1.8
OS: Windows 10
Document.
I’ve always had this issue and been using this software for years so this is likely happening by design but would love to hear if there’s a workaround or something.
Basically, copying and pasting a shape such as an arrow onto an image always causes the pasted shape to open a new page and places the shape into that new page instead of on the image where I want it. I then have to drag it down and then delete the blank page. Having to do this 10 times per image is quite tedious and time consuming. There must be a better way of doing it that I’m overlooking.
Any advice would be appreciated, thanks.
Just to clarify I’m using Desktop Editor Suite.
Thanks for the reply and suggestions. I’ve tried most of them over the years with little success. I didn’t know about Ctrl+D. I just tried it but it doesn’t appear to work for me.
Hi, @Atlas !
Thank you for your message.
Could you please record and send us a short video showing the exact steps and the result? This will help us understand precisely which scenario you mean and what behavior you are seeing on your side.
If the file size is too large for the forum, you can upload the video to any cloud storage and share the link with us here.
Hi @Marix
Thanks for the reply.
I haven’t been able to replicate the exact issue where a new blank page is inserted but I have captured a screen recording showing how highly variable the issue is even between 2 documents. Copy/pasting an arrow from one document has a different effect to copy/pasting from another very similar document.
If I’m honest I think what I originally reported is just an exaggeration of what I’ve been able to capture today. In some instances the issue is moving my image down a whole page and in other instances it’s moving it down by just a single line or two. In the third instance it partially hides it at the top of the image but at least it didn’t affect the document formatting.
OnlyOffice Copy-Paste Issue.mkv (1.7 MB)
I hope this helps and if the blank page issue crops up later today then I’ll try to screen capture it.
Hello, @Atlas !
Thank you for the video and the additional clarification.
We’ve passed the information to our QA team for verification, and we’ll get back to you here as soon as we have any news.
Hello, @Atlas !
We’ve confirmed that the behavior is caused by an extra empty paragraph being inserted when the shape is pasted, and we’ve linked your report to the existing internal bug report. Unfortunately, we do not have an ETA for a fix yet, but we’ll update this thread as soon as we have any news.
@Marix Thanks for the update. Hope to see this bug squashed soon as it’s been there for years! If I’d known it was a bug I would’ve reported it sooner … oh well.
You’re welcome, and thanks a lot for sticking with it and reporting it! We’ll update this thread as soon as there’s any progress to share.
