Copy Cell Outline Not Easily Discernible
Hello, I really like what is being done with OnlyOffice. One minor suggestion for improvement is that whenever I select cells that are being copied and press the copy button or use the CTRL+C keyboard shortcut, there isn’t a visible outline that shows that cells have been copied until I select another cell. Knowing if the cells have been copied would be helpful.
Hello @qualm
Thank you for the suggestion, we need some time to review it. Please await my feedback.
UPD: the suggestion has been registered, thank you for the interest.
